2001 Ford Taurus Stalling
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
KEVIN-2424
My Taurus will idle with no problem. I put the car into gear and drive a block and it will stop and surge repeatedly then completely die. I changed the alternator but it still does the same thing. Any ideas?
Feb 18, 2010 at 7:07 AM
BMRFIXIT
  • 19,053 POSTS
Can you keep it running with foot on gas and if so suspect IAC valve remove and clean or replace
Check for codes
Feb 18, 2010 at 9:09 AM
KEVIN-2424
No, it will idle on its own with no problem, I can put my foot into the gas while it is idling and the rpm's will go up normally. But when I put it into gear and try to drive no matter how much gas I give it it dies.
Thank you for any ideas you have.
Feb 19, 2010 at 1:08 AM
BMRFIXIT
  • 19,053 POSTS
next step is to check for fuel flow and pressure
Feb 19, 2010 at 8:42 AM
