2001 Ford Taurus Should I have fluid / filter changed.
189,599 MILES • 6 CYL • FWD • AUTOMATIC
JWYOUNG
Good day. I have a 2001 Ford Taurus SES (3.0 OHV Vulcan)
I recently had some maintenance done. The shop recommended changing the transmission fluid (getting brownish in color, no burnt smell)
The vehicle has 189599 miles.
I do notice an occasional transmission fluid leak after heavy driving (usually hot weather) after the car sits for a while. As long as the fluid is not low, it shifts well.
Is it advisable to have the service done? Bars makes a stop leak product for transmissions which is supposed to work better with new fluid.
I was just concerned after seeing a post about not servicing a high mileage transmission.
Thank you for your help.
Apr 7, 2010 at 5:50 PM
  • 75,988 POSTS
Change the fluid and the filter-Do Not Flush might make things worst.
Apr 7, 2010 at 7:56 PM
JWYOUNG
Thank you, rasmataz,
Glad I didn't give into there flush idea.
What do you think about another shot of Bar's also? They make a regular tranny stop leak and also a "Transmission Repair" version that helps stabilize fluid and I believe help protect gears.
Thank you
Apr 8, 2010 at 3:25 PM
  • 75,988 POSTS
I've never use it -seen it before Go for it
Apr 9, 2010 at 6:47 AM
