2001 Ford Taurus Rear wheel whine
2001 FORD TAURUS
99,500 MILES • 6 CYL • FWD • AUTOMATIC
POCA1976
I'm getting a constant whine from the rear of the car while moving. Tires are in good shape. I will be replacing the struts with a quick strut set this week. A broken piece at the top of the current right strut causes a pounding sound when on rough roads.
At 99K miles should I be replacing or just repacking the rear wheel bearings? Thank you.
May 5, 2010 at 3:07 AM
BMRFIXIT
  • 19,053 POSTS
Hub and bearing assembly is not serviceable. Entire assembly must be replaced if defective
May 5, 2010 at 10:48 PM
