2001 Ford Taurus oil pan gasket
136,000 MILES • 6 CYL • 2WD • AUTOMATIC
DAVID CATES
2-3 months ago I did a front engine cover gasket replacement. I had to replace the oil pan gasket in the process. The service manual said about 106 ftlbs for the bolts. I thought that was extremely high (actually broke one bolt using the torque wrench before I just torqued by feel). Now the gasket is pushed out from between the pan and the engine. Was it to tight? What torque should I set it at? Or is it something else?
Oct 15, 2009 at 12:33 PM
BMRFIXIT
  • 19,053 POSTS
Apply a bead of silicone gasket and sealant in 2 places where the cylinder block meets the front cover and in 2 places where the rear main bearing cap meets the cylinder block.
The new gasket I believe was updated to include a lip to hold in on the pan
106ftlb is an extrem
it should be around 10 ftlb
Oct 15, 2009 at 1:10 PM
