2001 Ford Taurus Not starting
56,000 MILES • 6 CYL • 2WD • AUTOMATIC
HOWARD RUBIN
When turning the key in the ignition the engine turns over starts momentarily but then coughs 2 or 3 times and then dies. The problem seems to happen only when the engine is hot. I does not happen every time the engine is hot: it is an intermittent problem.
Apr 17, 2009 at 3:23 AM
BMRFIXIT
  • 19,053 POSTS
check fuel pressure
suspect fuel pump
Apr 17, 2009 at 6:36 AM
