2001 Ford Taurus not shifting properly
81,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROBROB1985
Two things have recently started with my transmission, 1st on a cold start and shifting from park to drive you hear a clank noise coming from the transmission. 2nd While driving it feels like the transmission skips 3rd gear, it goes from 1st to 2nd smooth then all of a sudden it drops in this low gear with a thump, assuming that this is 4th gear. Now if you keep your foot on the gas to stretch the gears out it will go into 3rd. To describe the feeling better is like if u were in manual and u went from 2nd to 4th gear the idles drop low and the car take a while to pick up speed in the low gear. this is what it does.
thanks for your time
Sep 21, 2008 at 6:57 AM
MERLIN2021
  • 17,250 POSTS
Not sure if this Tech bulliten pertains to you but have a look.
3.0L VULCAN AX4S/AX4N - HIGH IDLE/ROUGH GEAR ENGAGEMENTS WHEN ...
Page 1 of 2
3.0L VULCAN AX4S/AX4N - HIGH IDLE/ROUGH GEAR ENGAGEMENTS WHEN COLD
TECHNICAL SERVICE BULLETIN
Reference Number(s): 01-8-1, Date of Issue:  April 30, 2001 Related Ref Number(s): 01-8-1
ARTICLE BEGINNING
DRIVEABILITY - HIGH IDLE COLD IN GEAR OR WHEN COLD SHIFTING FROM PARK/NEUTRAL TO DRIVE/REVERSE - VEHICLES EQUIPPED WITH 3.0L 2 VALVE VULCAN ENGINE - BUILT BEFORE 3/1/2001 ONLY TRANSAXLE - AX4S - AX4N - ROUGH ENGAGEMENT INTO GEAR WHEN COLD - ROUGH COLD SHIFTS - RPM SURGE DURING 2-3 COASTING UPSHIFT - VEHICLES EQUIPPED WITH 3.0L 2 VALVE VULCAN ENGINE - BUILT BEFORE 3/1/2001 ONLY
Model(s):
FORD: 2001 Taurus MERCURY: 2001 Sable
Bulletin No.: 01-8-1
Date: April 30, 2001
ISSUE
Some vehicles equipped with a 3.0L Vulcan engine built prior to 3/1/2001 may exhibit a perceived:
 High idle when shifting from Park/Neutral to Drive/Reverse on a cold start
 High creep speed in Drive or Reverse
 Rough and harsh shifts while driving when cold
 Cold engine harsh Park/Neutral to Drive/Reverse engagements
 Engine rpm surge during a 2-3 coasting upshift at approximately 40 km/h (25 mph)
This may be caused by the calibration of the Powertrain Control Module (PCM).
ACTION
Verify condition. If normal diagnostics cannot pinpoint condition, reprogram the PCM. Refer to following Service Procedure for details.
http://www.ondemand5.com/mric/common/asp/printart.aspx
9/21/2008
Page 2 of 2
SERVICE PROCEDURE
1.Reprogram the PCM to the latest calibration. Refer to the PCM Calibration Information Chart in Fig. 1 for applications.
NOTE: If using a New Generation Star (NGS) tester to reprogram the PCM, the NGS may ask "Would You Like To Modify Any PCM Parameters?" Answer "NO" to this question. This will prevent changes to the tire size and axle ratio. If "YES" was inadvertently selected, it may be necessary to enter 797 for tire size and 3.47 for the final drive axle ratio.
2.Advise the customer that it may take several drive cycles (dependent on cycle) before the PCM will completely adapt to the new calibration.
Obtain an Authorized Modifications Decal (FPS 8262 - obtainable through DOES II, 25/pkg) and list the date, dealer number, and summary of modifications performed. See Fig. 2 . Select a prominent place adjacent to the Vehicle Emission Control Information Decal suitable for installing the Authorized Modifications Decal. Clean the area, install the decal, and cover it with a clear plastic decal shield.
WARRANTY INFORMATION
WARRANTY STATUS: Information Only.
OASIS CODES: 501000, 502000, 503000, 504000, 610000, 610700, 612000, 612500, 612600, 617400, 619400
Fig. 1: PCM Calibration Information Chart
Fig. 2: Authorized Modifications Decal
© 2007 Mitchell Repair Information Co., LLC.
9/21/2008
Sep 21, 2008 at 7:06 AM
