2001 Ford Taurus No Acceleration
185,000 MILES • 6 CYL • FWD • AUTOMATIC
CASINOMAN
My car doesn't seem to be shifting into gear. I have Park but nothing else. I can shift it at the column and see the linkage moving, but i can't hear/feel the the clutch engage or a change in engine noise. It is not bound up as i can push it in any gear except park. The engine appears to be running fine, and there were no codes stored on the ECM. The tranny fluid is full and appears to be clean. No matter what gear I am in when the accelerator is pressed i get high RPMs but no forward or reverse movement.
I had recently started to feel a vibration and some noise comeing from the front drivers side of the engine compartment. Could this be the torque converter?
Sep 12, 2010 at 8:09 AM
  • 110,248 POSTS
Did this happen all at once? Does the speedo needle move when you place it in gear?
Sep 13, 2010 at 4:16 AM
