2001 Ford Taurus Missfire P0302 on 3.0 V6 OHV
108,000 MILES • 6 CYL • FWD • AUTOMATIC
CRAIGFORD
I have replaced the 02 sensor, injector for cyl. #2, wires, plugs it was tune up time anyway. I just replaced the cam sensor and sysc. shaft. I am getting a 302 that I can get rid of. Compression is within specs. plug is clean, and I am getting a chirping/whining sound coming from the upper intake(It was worse until I changed the cam parts).
I metered these sensors and they test ok: MAF, TPS and ERG solenoid. Vacuum hose look good and I replaced the PVC valve, hose and cup.
Nov 12, 2009 at 2:52 AM
CRAIGFORD
[quote:71c7d4e300="craigford"]Engine Mechanical problem
2001 Ford Taurus 6 cyl Front Wheel Drive Automatic 108000 miles
I metered these sensors and they test ok: MAF, TPS and ERG solenoid. Vacuum hose look good and I replaced the PVC valve, hose and cup.[/quote:71c7d4e300]
I guess no one knows the answer!
Nov 22, 2009 at 2:07 AM
