2001 Ford Taurus Misfire problems
117,000 MILES • 6 CYL • FWD • AUTOMATIC
SSJROB4
Hi, I've been having some misfire issues with my car. When checking the codes I had a misfire in the 5th cyl. I've replaced the air filter, spark plugs, wires, fuel filter, pcv valve and had a fuel injection cleaning done none of which helping with my problem...I'm going to test the coil packs next but if they turn out fine would you have any idea on what could be the cause of this?
Mar 26, 2009 at 12:39 PM
BMRFIXIT
  • 19,053 POSTS
Coil is a common problem should check it and or replace it
Mar 26, 2009 at 12:42 PM
