2001 Ford Taurus with 24 valve Duratec V6 engine. Engine misfire on 2 & 6. Diagnosis showed bad coil pack. Replaced with coil pack from O'Reillys auto store. Run great for 3 days. Started the same problem again. Diagnosis showed same problem, different cylinders. Coil pack replaced with another from O'Reilly's. Ran 15 miles before check engine light came on. Mechanic says it has to be a bad ECM (computer)?
HELP!
HELP!
Dec 15, 2009 at 11:37 AM
