2001 Ford Taurus MIL goes off as dash dimmer switch increas
100,500 MILES • 6 CYL • FWD • AUTOMATIC
EACH
The MIL went on. I put the reader on it and there were no codes. I then turned headlights on and the MIL went out. I then tried the dashboard light dimmer and found when it was turned down all the way, the MIL was bright. As I increased the dimmer, the dashboard lights got brighter, the MIL got dimmer until I increased the dashboard lights all the way and the MIL went out. What gives?
Feb 5, 2009 at 10:16 AM
MASTERTECHTIM
  • 4,750 POSTS
i would suspect a problem in the circuit board in the dash cluster. although i have never seen this before, it seems as the check engine light is backfeeding through the running light circuit.
Feb 7, 2009 at 11:27 PM
