2001 Ford Taurus Keyless entry code
65,000 MILES • 6 CYL • FWD • AUTOMATIC
STONEWALL
I don't have the keyless code entry for the driver door keypad. I think it may be taped to the computer unit. Where is the computer physically so I can look there? Is there a way to recover the code? Would Ford have the code somewhere on file?
Apr 27, 2009 at 2:33 AM
BMRFIXIT
  • 19,053 POSTS
Here is a guide that will show you how to turn off the alarm
https://www.2carpros.com/articles/how-to-reset-a-security-system
Also, check left side of dash around fuse box.
Note: Factory code is printed on owner's wallet card, located in glove compartment and on Generic Electronic Module (GEM).
Note: System only allows one personal code to be programmed. Any existing personal code will not need to be erased to program a new one.
Enter permanent factory keyless entry keypad code. Press 1/2 button within five seconds to activate programming mode. Holding 1/2 button for more than two seconds after activation will erase the stored personal code.
Within five seconds, enter new five-digit keyless entry keypad code. Power door locks will lock and unlock to confirm new code is programmed.
Jan 17, 2017 at 5:28 AM
