2001 Ford Taurus jerking
LEE08
Shakes or Wobbles problem
2001 Ford Taurus 6 cyl Front Wheel Drive Automatic 103k miles
on my 01 ford taurus the rpm revs to 5 or 6 while turning then goes back to normal. i just had a new transmission put in and been to so many mechanics but none seem to no whats wrong! could you help me out?
Apr 21, 2008 at 10:54 AM
FLEXY5
  • 512 POSTS
It either has an sir pocket in the trans somewhere or the fluid level isn't right. If neither of those is the case, remove the trans pan and check the filter. There are o-rings where the filter attaches to the case and there may be an issue with them. check these and post back. We can go from there.
Apr 21, 2008 at 3:17 PM
