I have a 2000 ford taurus. the egine started idling at 2000 rpms. after a few times doing this, it started climbing to 3000+ rpms. i have replaced both the IAC and the EGR. if i unplug the IAC, the car willl "run" at apprx 500 rpms. however it will stall unless i goose the gas. once it is warm it still runs rough and still idles at 500 rpm.
the local ford mechanics said it could be the computer- they were not sure, they wanted to do ss of elimination.
the scanner shows error code for iac unplugged- no error code when iac is plugged in.
any idea's.
Thanks
any idea's.
Thanks
Dec 3, 2009 at 5:40 AM
