Radiator hose
2001 FORD TAURUS
GUMBY1
Engine Cooling problem
2001 Ford Taurus 6 cyl Two Wheel Drive Automatic
I REPLACED THE COMPRESSOR FOR AC UNIT AND TOOK ALL THE HOSES OFF THAT WHERE IN THE WAY FOR MY PROJECT. I HAD SOME OTHER KNUCKLE HEAD HELPING AND HE TOOK OFF THE LOWER RADIATOR HOSE AND THE CONNECTOR PIPE THAT BRANCHES IN A Y WITH THE ONE TUBE GOING ACROSS THE FRONT OF THE ENGINE AND THE OTHER SMALLER (PROBABLY 3/4 IN.) METAL TUBE GOES THREE INCHES OR SO AND THEN IT WOULD CONNECT TO ANOTHER RUBBER HOSE ???? THIS IS WHERE MY PROBLEM START I CANT FIGURE OUT WHERE OTHER END IS......
Nov 5, 2009 at 6:53 AM
BMRFIXIT
  • 19,053 POSTS
the 3/4 hose goes up in to the inner fender
it branch from the lower radiator hose and up in to the fender and to the fill box on the side
Nov 5, 2009 at 10:02 AM
