Blower motor works on high only?
95,000 MILES • 6 CYL • 2WD • AUTOMATIC
ANGELTAZ
The heater only works on high. The switch control has already been changed. What could be the problem.
Nov 30, 2008 at 5:03 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Sounds like you may have a faulty blower motor resistor. Located near blower motor assembly in dash. Check this first and I will follow up.
Nov 30, 2008 at 5:34 AM
ANGELTAZ
That was the problem it didn't look bad, but when you put a Multimeter across it was open. I replace and it now works fine. Thanks for the help.
Dec 9, 2008 at 10:47 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Great, glad you have it working again.
Thanks for using 2carpros.com!
Dec 9, 2008 at 4:05 PM
