I purchased a portable heater/defroster to be plugged into cigarette lighter. It keeps blowing fuse. My heater/defroster does not work and I tried to have this fixed, but it is too expensive.
Do you know what I can do? I want to first of all replace fuse, but cannot find fuse box. Secondly, if fuse keeps blowing do you have any suggestions?
Thanks.
Friday, December 5th, 2008 AT 9:27 AM
DAVE H
MECHANIC
The fuse box is located under left hand side of dashboard ... cigarette lighter fuse is #13 the fuse in there should be 20 amp ... check fuse #28 that is the fuse for you cars blower motors ?? do the blower's not work at all ???
Friday, December 5th, 2008 AT 9:52 AM
OHIOCIN
MEMBER
Yes, the blowers work, but only cold air. AC works, but no heat or defrost
Friday, December 5th, 2008 AT 10:10 AM
DAVE H
MECHANIC
Can you alter the direction of the blowers. Ie. From screeen to footwell?. But your not getting any hot air, just cold?. Sounds like the heater core is blocked?
