When 1st key on and while engine cranking fuel pump should be on
best if you can check for power at the pump connector
also you may try this have a helper crank it as you hit the mid of the tank with a rubber mallet
if that get it started for sure you need new fuel pump
SPONSORED LINKS
Wednesday, February 3rd, 2010 AT 8:47 PM
