2001 Ford Taurus Error Codes Reads P0301& P0302???
121,000 MILES • 6 CYL • FWD • AUTOMATIC
MTGOODWIN88
I have had the transmission filtered and changed..The same with the oil...Also, I had new spark wires put in and spark plugs..Also, a new coil pack..I dont know what the problem is..My check engine sign ( a yellow engine) is still on...And the car still shakes a little..When driving it acts like it dont want to go over 20 mph..I try not to push it or floor the gas.. I have took my car to different auto shops..All their machines reads P0301 and P0302..Something about a misfiring..This was before and after replacing everything..What could it be still? You know us women know nothing about cars...HELP!
Apr 8, 2010 at 12:26 PM
BMRFIXIT
  • 19,053 POSTS
The codes you have is for cylinder misfire
Most common a bad ignition coil
1st step check and do a tune up
Check injectors and do a compression test
Apr 8, 2010 at 3:48 PM
