2001 Ford Taurus engine stalling in reverse
105,000 MILES • 6 CYL • FWD • AUTOMATIC
REDSKIN
  • 6 POSTS
symptom just started, 2x when put into reverse engine stalls. Also when in drive around 2000 rpm car feels like it is losing power. No engine codes. Transmission problem? Torque Converter?
Mar 26, 2009 at 12:42 PM
BMRFIXIT
  • 19,053 POSTS
check tranny fluid
do a tranny fluid and filter change
Mar 26, 2009 at 12:44 PM
REDSKIN
  • 6 POSTS
tranny fluid and filter was just serviced and fluid is at proper level
Mar 26, 2009 at 11:57 PM
BMRFIXIT
  • 19,053 POSTS
No codes !
Check idle air control valve
check neutral safety switch if lined up
Mar 27, 2009 at 6:33 AM
