2001 Ford Taurus Engine Problem with Taurus
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
GOLDENPATRIOT
My son was driving his car through heavy snow yesterday, got stuck, rocked the car to get out and shortly thereafter the oil light came on. He continued to drive and began hearing a tapping/clicking sound and then a backfire. He turned the engine off. We took it to a local station that does not do engine work and they put some oil in, started it up and said it is the engine.
There is no smoke. Any idea how bad this may be?
Thanks so much!
Dec 20, 2008 at 2:37 AM
SCHRIMPIEMAN
  • 166 POSTS
That's a tough question to answer because your audience cannot hear the car running / clacking.
If it's more of a clicking sound, the valve train may be damaged. The heads need to come off and be reconditioned.
If it's a CLACKING sound, chances are the engine rod bearings were starved of oil and are now damaged due to friction wear. The only way I would tackle worn rod bearings would a complete engine tear down, inspection, and reassembly. Keep in mind, not only the bearings may be damaged, but the rods may have spun the bearings, and there may be scratches on the crankshaft journals. All these need to be in perfect working order with bearing clearances to match. Otherwise, you're looking at bearing failure down the line.
Not having smoke from the tailpipe or otherwise is not relevant to the situation.
Dec 21, 2008 at 11:36 AM
GOLDENPATRIOT
Thank you very much for your response!
Dec 21, 2008 at 11:58 AM
