2001 Ford Taurus Cuts off???
134,569 MILES • 6 CYL • FWD • AUTOMATIC
HPPYCMPR1213
Car will be running fine...then shut off for no apparent reason. Have changed fuel filter and pump. Checked wires and distributor...am completely baffled!! Other than periodically dying...the engine otherwise runs very strong. Have also tried dif grades of gas with no difference. BTW...also have an '86 buick regal that does the same thing :-)
Mar 25, 2010 at 5:45 AM
BMRFIXIT
  • 19,053 POSTS
Will it start back up or have to wait for it
check for codes
remove and clean IAC valve
if no codes and if was able to start back up again
Mar 25, 2010 at 11:32 AM
HPPYCMPR1213
Took the IAC off...cleaned it like you said, and so far two days of a perfectly running vehicle!!! Thank You!!
Mar 28, 2010 at 2:19 PM
