2001 Ford Taurus compressor/condenser not kicking in
175,000 MILES • 6 CYL • FWD • AUTOMATIC
JAMES_BL2003
I recently replaced the motor in this tarus I own. However since then I tried recharging the ac on it and not getting any response from it it's not cooling and it seems like the compressor is not kicking in I've check my plugs that connect to it and check what fuses I could find that should work it. Please help!!!!!!
Aug 5, 2008 at 10:50 AM
JUSTDON
  • 161 POSTS
AC compressor relay?? Small relay in the box under the hood. Maybe #33
If there are other relays with the same number on them, you can try switching relays just long enough to see if that is the problem. ( don't forget to switch them back after checking )
Aug 6, 2008 at 1:33 AM
