2001 Ford Taurus check engine light on, runs rough
125,000 MILES • 6 CYL • FWD • AUTOMATIC
BW19526
2001 Taurus ran fine on the way home from work, 1 hour expressway drive. Went back out 1 hour later, check engine light blinking, running poorly, no power, backfiring. I was low on oil, just above the minimum line on the dipstick but still within range. Put 1.5 quarts in. Still have the same issues. Let it sit overnight, nothing has changed but the ck engine light is on steady. Help!
Aug 18, 2009 at 11:15 PM
BMRFIXIT
  • 19,053 POSTS
Blinking check engine light is an indication of engine misfiring
have to check for codes
suspect need an engine tune up and also check coil
Aug 18, 2009 at 11:42 PM
