2001 Ford Taurus CHANGE THE TRANS PAN SEAL
TOOLBELTDIVA
Transmission problem
2001 Ford Taurus 6 cyl Front Wheel Drive Automatic
I NEED TO KNOW HOW TO CHANGE THE SEAL ON THE TRANSMISSION PAN
Oct 21, 2010 at 1:29 AM
  • 110,248 POSTS
The trans pan seal is nothing more than a gasket. Remove the pan (carefully because fluid will leak out), properly clean both the surfaces, pan and trans case, peen pan bolt holes flat, and replace gasket and fluid lost.
Oct 22, 2010 at 12:14 AM
