2001 Ford Taurus Car won't start
51,000 MILES • 6 CYL • 2WD • AUTOMATIC
AJACKS
I own a 2001 Ford Taurus that is stuck in my driveway because it won't start. I do not think the battery is the problem, since all systems work and the lights come on. I have attempted to even charge it with no luck. I believe the problem is the starter, however how can I tell for sure that is the problem? Also, I can I see if a relay is bad? Thanks
Feb 14, 2009 at 1:31 AM
  • 110,251 POSTS
Hi:
thre is a relay block under the hood. They should be marked for their purpose. You can switch them out with each other to try, just make sure the relays have the same part number.
Next, you have two choices with the starter. Remove it and have it checked at a parts store, or try this. Have a helper turn the key in the start position. At that time, check the smaller wire going to the starter. It should get 12 volts when in the start position.
Let me know what you find.
Feb 14, 2009 at 10:17 AM
