2001 Ford Taurus car will not start. Will spin over
LORMEE6
  • 2001 FORD TAURUS
  • 6 CYL
  • FWD
  • 100,000 MILES
We put a crankshaft sensor and acamshaftsensor and a ciolpack and a oilpressure switch. And it still will notcrank help please
Sunday, December 20th, 2009 AT 9:15 PM
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard.
Monday, December 21st, 2009 AT 3:47 AM
