2001 Ford Taurus car vibrating high speed
57,000 MILES • 6 CYL • 2WD • AUTOMATIC
INNOVISION
I did by my self 4 new quick strust , 2 new ball joints,2 new outer tie rod end ,bring shop put in 2 new half shaft and 4 new tie , anligment 2 time bring to dealer force balancing 1 tim stil feel vibrating 65miles up to 80 when I step on gas but when I release gas let it going down 80 to 60 miles I din't fell it vibrating from steering at all .Another question please take car to dealer change coolant flush but I drive home and check I saw coolant was up to top of cap pass max line level is that my car will damage water pump or anythings eles ? thank you
Apr 7, 2009 at 4:08 PM
  • 31,937 POSTS
H there,
If you are getting a body only vibration it will be a rear wheel rear end problem, start looking here, as for the coolant, if the engine was hot the coolant has expanded, re check the level in the morning when its cool and adjust to max limit then.
mark (mhpautos)
Apr 7, 2009 at 7:42 PM
INNOVISION
giveme time let I go check my cars
Apr 8, 2009 at 11:04 AM
INNOVISION
how do I vote
Apr 9, 2009 at 11:32 AM
  • 31,937 POSTS
Hi there, you can leave feed back by clicking the blue link next to the starts, or contact the 2carpros site direct and let them know how you feel about the service offered, good luck.
Mark (mhpautos)
Apr 9, 2009 at 12:04 PM
INNOVISION
I vote but the web keep ask me why give zero I don't know wat from high to low point
Apr 10, 2009 at 12:38 PM
  • 31,937 POSTS
HI there.
Its a bit of a failing in the system that now users cant sent points or vote until they accrue points them selfs, so may be contact mike@2carpros.com and let them know how you like the site, and how you were not able to vote,
Thank you for you support and i hope that you have been happy with the service.
Mark (mhpautos)
Apr 10, 2009 at 4:13 PM
