2001 Ford Taurus car stops?
137,538 MILES • 6 CYL • FWD • AUTOMATIC
TRICKS19
okay so here's the deal. my car is loud i was told by a mechanic that i need my exhaust to be fixed. So when i drive it drives fine except for a little slug here and there. so when i come to a complette stop for too long or if i go at a low speed(0-5)mph it will stop, but I can restart it right away with no problem!.....any idea what it may be? something with the idle control valveor idle air passage?
Jan 16, 2010 at 2:16 PM
BMRFIXIT
  • 19,053 POSTS
Check for vacuum leaks
check if due for tune up
if have check engine light on ,should check and get the codes
check idle air control valve maybe remove and clean
Jan 16, 2010 at 2:20 PM
