2001 Ford Taurus AC/HEAT
96,000 MILES • 6 CYL • FWD • AUTOMATIC
MHELM2359
Just recently had AC recharged. Its been working fine. all of a sudden 2 days ago tried to turn AC on and got very hot air. I think it is stuck on heat. Has digital climate control. When I set it to 60 degree it still blows very hot air. So far I only checked some fuses. Is there also a relay that could control this? What could be causing this problem?
May 6, 2010 at 10:59 AM
BMRFIXIT
  • 19,053 POSTS
suspect blend door or actuator
remove radio and check actuator operation
May 6, 2010 at 11:13 AM
