2001 Ford Taurus 2001 Taurus
99,999 MILES • 6 CYL • FWD • AUTOMATIC
BXC130
I have a 2001 Ford Taurus. For the past few days the Check Engine Light was on, although the car continued to run fine. This morning while pulling away from a parking spot the car shut down. When I tried to restart the car it would not crank and there was no power to any of the cars electrical componets. After sitting a few few minutes I attempted to restart the car. The car started and the Check Engine light was no longer on. I took the car to my mechanic but he said he could not test for the trouble code while the light was not lit. He did check the charging system and said everything was fine. I returned home and after the car sat for a while a I once again tried to start it. This time the electrical system was shut down again as before, and the Check Engine light was still not lit up. Another attempt later and the car started fine and still no return of the check engine light. Any suggestions?
Mar 9, 2010 at 6:39 AM
BMRFIXIT
  • 19,053 POSTS
Sounds as the battery terminals loose
and that would also explain the no codes and no data from the PCM
remove battery terminals check ,clean and tighten
or replace if needed
Mar 9, 2010 at 10:16 AM
