2001 Ford Taurus 2001 Ford Taurus Temp Problem
50,000 MILES • 6 CYL • FWD • AUTOMATIC
FITS64
I noticed driving about 45-50 MPH last night that my temp gauge was reading high, it did not go into the red and I didn't get any engine lights
This morning when i checked the engine coolant it appears that it has all leaked out. I checked the oil and it seems normal.
Is is possible that I have damaged the head gasket, the car was running normal.
Thanks
May 8, 2010 at 4:32 AM
BMRFIXIT
  • 19,053 POSTS
yes it is possible that you have a bad head-gasket
but need few tests 1st to eliminate other possibilities too
fill system and check for leaks
common area that seen it leaks from
heater core lines by the firewall
overfill tank on the side inner fender
have it pressure test to check for leaks
May 9, 2010 at 12:39 PM
