2000 Ford Taurus A/C Compressor Cycling
A4DRIVR
I have a 2000 Ford Taurus w/ 3.0 V6 (95,000 miles) and recently the A/C began to blow hot. I checked the R-134a pressure in the system. The low side was approx. 40 psi at 70F, however the high side was only between 50 and 100 psi. I noticed that the A/C compressor would cycle, but would not remain on for more than a matter of seconds. When the compressor kicked on, pressure would rise to just under 100 psi (and would possibly rise higher if the compressor would stay on). Then it kicked off and would drop back to 50 psi. I'm not sure what would cause this... and any help pointing me in the right direction would be much appreciated.
Some additional info... the car has the manual style A/c controls. In addition, when the controls are switched into A/C the cooling fans kick on as they should.
Apr 2, 2007 at 5:45 AM
MERLIN2021
  • 17,250 POSTS
until the compressor kicks on for more than a sec or 2, 40 psi at idle, with the pump not running is low should read about 50. Try bypassing the pressure cycling switch with a jumper wire. This will kick on the compressor. Fill the system from the low side then remove the jumper. DO NOT RUN with jumper...will FRY compressor! If this dosen't solve the problem replace the pressure switch.
Apr 2, 2007 at 7:49 AM
A4DRIVR
If I remove the switch, will the system vent to atmosphere? Will this switch need to be replaced by a shop with the proper capturing system for the freon? Just trying to determine if replacing the switch is something I can do in my garage...
Apr 2, 2007 at 8:31 AM
Suggested Repair
Low-side pressure is low and the compressor is short-cycling. Briefly jumper the pressure cycling switch only long enough to run the compressor while charging from the low side, then remove the jumper immediately. Do not operate the system with the jumper installed. If charging does not fix the cycling, replace the pressure cycling switch.
Conversation Summary
A 2000 Ford Taurus with manual A/C controls blows warm air and the compressor cycles for only a few seconds. Low-side pressure was about 40 psi and high-side pressure stayed roughly 50-100 psi; the cooling fans still come on with A/C selected. The expert said idle pressure with the compressor off should be about 50 psi, suggested briefly jumpering the pressure cycling switch to charge from the low side, warned not to run with the jumper installed, and recommended replacing the switch if charging does not solve it. The owner then asked whether removing the switch vents refrigerant and whether a shop must capture it; that question was not answered.
