My mechanic is overloaded right now and I’m trying to find an answer for an A/C problem. I have a Taurus that blows heat when the A/C is engaged. It just happened over night about two weeks ago and I’ve been trying to get a handle on what’s wrong ever since. The compressor is working and I had my mechanic add a can of Freon to the system two days ago. I located the blend actuator door last night and found it to be working properly. That’s one item off the list of things that are causing my A/C problem. Do you have any thoughts on what should be the next check?
Aug 3, 2007 at 3:50 AM
