2000 Ford Taurus won't go into gear
190,000 MILES • 6 CYL • 2WD • AUTOMATIC
HOGANMB80
when I start my car I can't put my car in gear. however if I just turn it on I can put it in nuetral, start the car, and then I have no problems. I have no problems starting it, the transmition is not slipping, it just won't go in gear if it's running. what could the problem be
May 14, 2008 at 9:33 AM
SPORTSBUM1622
Did you ever get any good advice on the problem? I'm having the same trouble with a 98 taurus.
[quote:0ca91becc5="hoganmb80"]Transmission problem
2000 Ford Taurus 6 cyl Two Wheel Drive Automatic 190000 miles
when I start my car I can't put my car in gear. however if I just turn it on I can put it in nuetral, start the car, and then I have no problems. I have no problems starting it, the transmition is not slipping, it just won't go in gear if it's running. what could the problem be[/quote:0ca91becc5]
Jun 1, 2008 at 6:30 PM
