2000 Ford Taurus Window Washer Fluid
180,000 MILES • 6 CYL • FWD • AUTOMATIC
SROSERA82
I was wondering what can be done to fix a problem with the windsheild washer fluid. I live in Wisconsin and it has been extremely cold here recently and the washer that was in the car's reservoir tank I just found out was only good down to 32 degrees F. Is there any good way to fix this problem or do you have to put the car in a heated garage and let it dethaw and then drain the tank?
Dec 25, 2008 at 4:27 AM
BLACKOP555
  • 10,386 POSTS
either you have to put it in a heated garage. keep pouring boiling hot water in it and letting it overfill till its all thawed out or remove the resevoir and bring it inside.
Dec 25, 2008 at 9:08 AM
