2000 Ford Taurus window
63,000 MILES • 6 CYL • FWD • AUTOMATIC
ADEN
drivers side window is stuck when i try too raise it up i hear a clicking sound is this easy too fix?
Oct 24, 2008 at 7:21 PM
MASTERTECHTIM
  • 4,750 POSTS
sonds like may be a window regulator problem. these can be tricky to replace, time consuming. first remove the door panel and see if you can see if the window regulator is broken then we can go from there
Oct 24, 2008 at 11:26 PM
