2000 Ford Taurus will crank but won't start....fuel pump?
100,000 MILES • 6 CYL • FWD • AUTOMATIC
HOUSEMAN
I had to jump this vehicle to get it home. I cleaned the battery terminals which had some build up on them then I put a 12 volt- 6 amp charger on the battery. it started and ran one time for a few minutes. I have not been able to get it started since. there is plenty of cranking power, but not a pop from the engine? what do you think?
THIS SITE IS A HUGE DECEPTION!
WHY AREN'T YOU HONEST FROM THE OUTSET THAT IF YOU WANT A GENIUINE ANSWER FROM AN ACTUAL TECHNICIAN IT WILL COST YOU
Nov 10, 2008 at 11:56 PM
RENAUDTN
  • 636 POSTS
'Genuine technicians' do answer some questions for free, but they obviously give priority to questions that come with a donation. This website is actually very honest up front: "Our Technicians and MEMBERS answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. "
Although not a certified 2carpros technician, here are my suggestions, for what it's worth:
-have your battery and alternator tested at an autopart store
-although you said you have plenty of cranking power, I would still check the starter circuit (voltage drop test).
-when you crank your engine, check for sparks
-check your fuel pressure
-do a compression test on each cylinder
If you do the above, you should find what's missing (spark, fuel, compression, cranking power).
Nov 11, 2008 at 3:30 AM
