Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Taurus
Drivetrain
Transmission
Symptoms
Not Shifting
2000 Ford Taurus want shift
2000 FORD TAURUS
202,000 MILES • 6 CYL • 2WD • AUTOMATIC
GHUFF2
MEMBER
1 POST
will not shift to overdrive
Feb 6, 2010 at 6:43 AM
BMRFIXIT
Experienced Mechanic
Check tranny fluids
Check for codes
Is OD light blinking!
Suspect internal tranny valve body may need to be removed
Feb 6, 2010 at 11:31 AM
FRAJAGAMO
MEMBER
I has this problem with my son taurus, you need to replace the coil ignition.
Feb 17, 2010 at 1:00 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
