2000 Ford Taurus Wagon, Auto., 3.0L with 140k miles
GLC4292
The car won't start unless the gas peddle is used. It will not idle without pressure on the gas peddle. In the past there were a couple of instances where I had to use the gas peddle to start it. My local garage has changed a sensor that is in the $300+ dollar range without much success. His computer tells him that the car thinks it is at an altitude of 5,000 feet. The car has been there for nearly 2 weeks.
Oct 30, 2007 at 3:15 PM
MERLIN2021
  • 17,250 POSTS
Should be the mass air flow sensor then, try unplugging it to see if it runs, if not it's either a wiring problem in that cucuit, or the PCM needs a reflash...or replace.
Oct 30, 2007 at 7:48 PM
2CARPRO JACK
  • 11,533 POSTS
Have them try an IAC motor
Oct 31, 2007 at 12:39 AM
