Air only blows out the defroster. Will not blow out the vents. Doesnt matter where I turn the dial, it will only come out the defroster.
Aug 18, 2008 at 11:35 PM
2CARPRO JACK
✓Experienced Mechanic
There is a source vacuum line that comes out of the firewall where the a/c equipment is, should go to either the engine or a vacuum resevior, be sure the line is hooked up and not cracked/broken. Defrost is the default for a no vacuum situation
Aug 19, 2008 at 1:17 AM
KENGAITHER
MEMBER
1 POST
Is this something that I can do myself? or should it be done by a mechanic. I called a mechanic today and he said it sounds like a blend door activator and that I was looking at $200-$300 to fix it.
Aug 19, 2008 at 1:40 AM
2CARPRO JACK
Yes, check the vacuum first, the blend door works hot/cold not defrost to other vents
