2000 Ford Taurus trans axle cooling sensor
120,000 MILES • 6 CYL • FWD • AUTOMATIC
CESLKIN
where is the trans axle cooling sensor located?
Mar 14, 2010 at 12:27 PM
BMRFIXIT
  • 19,053 POSTS
Transmission Fluid Temperature Sensor
The Transmission Fluid Temperature (TFT) sensor is located on valve body. The PCM monitors voltage across the TFT thermistor to determine transaxle fluid temperature. Depending on temperature, PCM controls line pressure, shift scheduling and TCC operation. Malfunction of sensor will cause incorrect line pressure and possible lack of TCC operation.
Mar 14, 2010 at 1:26 PM
