2000 Ford Taurus Trans axle
10,700 MILES • 6 CYL • FWD • AUTOMATIC
PAUL CORNELIUS
Indicator light lights up for the trans axle to be checked. When engine is turned off and restarted the light go off, but comes on again. The light comes on when you start off in a hurry or when you go into passing gear. What is wrong? the transmission or the indicator light or a sensor in or on the transmission?
Apr 5, 2009 at 12:14 PM
JGAROFALO
  • 489 POSTS
Your problem is most likely a sensor. Have it checked for trouble codes.
When the transmission MIL lights up, it is an indication that the PCM is seeing a problem with the transmission electronics.
Apr 6, 2009 at 9:03 AM
