2000 Ford Taurus stops and idles high
150,000 MILES • 6 CYL • FWD • AUTOMATIC
AMYSPAKE
Hi. I have a few problems with my car. First, the engine light has come on and stays on. Second, it idles high when stopped. And third, whenever I come to a complete stop it wants to cut off and usually it does. HELP
Thank you for your reply, that is exactly what the problem was, and it only cost 60 dollars to fix. I was soooooo relieved. Thanks again!
Oct 29, 2008 at 12:27 AM
2CARPRO JACK
  • 11,533 POSTS
The check engine light may be the source of the problem. Have the PCM scanned for the code. Also check for vacuum leaks at the engine . It sounds like either a vacuum leak or the Idle Air Control Motor is bad
Oct 29, 2008 at 1:14 AM
