2000 Ford Taurus steering wheel vibration when car is at 50
94,000 MILES • 6 CYL • FWD • AUTOMATIC
MSWANK
Can you please tell me what would be causing my steering wheel to vibrate when the car is at speeds between 50-60 mph? I recently had the front end aligned and new struts put on the front as well.
Apr 3, 2009 at 1:26 AM
BLACKOP555
  • 10,386 POSTS
check the tires for damage and static unbalance. that can cause that problem.
also taurus's have problems with rotors warping if tires are not put on with a torque wrench. and with the calipers at close clearence that can cause the vibration at speeds.
check the tires first.
Apr 5, 2009 at 1:57 AM
