2000 Ford Taurus Starting problem
85,000 MILES • 6 CYL • FWD • AUTOMATIC
JETTRACK
My Taurus will not start, it turns over but does not engage, replaced the spark plugs and distributor module and the symptoms are the same. Figuring that it is a fuel issue just wondering where to look first?
Feb 25, 2010 at 2:17 AM
  • 75,988 POSTS
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Feb 25, 2010 at 9:54 AM
