How do you release the tention on the belt to change it?
Sep 13, 2010 at 8:56 AM
SATURNTECH9
✓Experienced Mechanic
What is the 8th digit of your vin so i can get you the correct info.
Sep 13, 2010 at 11:44 AM
YOUKNOWMYNAME67
MEMBER
there is a tensioner pulley located by your power steering pump.... my tarus uses a 15mm wrench i put that on the pulley relieve the pulley tension and replace the belt.
Sep 17, 2010 at 11:11 AM
SATURNTECH9
That's one way to do it but there is three engine option's for that year that's why i asked for the 8th digit of the vin so i knew which one of the three it is.
