How do you release the tention on the belt to change it?
Monday, September 13th, 2010 AT 3:56 PM
SATURNTECH9
MECHANIC
What is the 8th digit of your vin so I can get you the correct info.
SPONSORED LINKS
Monday, September 13th, 2010 AT 6:44 PM
YOUKNOWMYNAME67
MEMBER
There is a tensioner pulley located by your power steering pump. My tarus uses a 15mm wrench I put that on the pulley relieve the pulley tension and replace the belt.
Friday, September 17th, 2010 AT 6:11 PM
SATURNTECH9
MECHANIC
That's one way to do it but there is three engine option's for that year that's why I asked for the 8th digit of the vin so I knew which one of the three it is.
