2000 Ford Taurus rear tires wont move
119,395 MILES • 6 CYL • 2WD • AUTOMATIC
RUMNCOKE0482
my rear tires are locked up wont move when i put it in drive or reverse front tires are moving fine but rears wont move.
break fluid resivor is full
ebrake was never set or shows it is set but have applied and released
May 26, 2009 at 2:10 PM
  • 75,988 POSTS
Could be caused by weak or broken retracting springs on drum brakes, a jammed or corroded caliper piston, a floating caliper with badly corroded mounting pins or bushings (uneven pad wear between the inner and outer pads is a clue here), overextended drum brake self-adjusters or a sticky or frozen emergency brake cable
May 26, 2009 at 10:09 PM
