2000 Ford Taurus Rear Struts
NBESSELL
Suspension problem
2000 Ford Taurus 6 cyl Automatic 133000 miles
I recently replaced my rear strut assembly because my rear end was making a loud noise when I hit potholes. After changing the assembly the problem persists. PLEASE HELP!!!
Aug 30, 2010 at 2:53 PM
  • 110,251 POSTS
Were the strut plates in good condition? Also, were all bushings in good condition?
Sep 1, 2010 at 3:11 PM
NBESSELL
I found that my car has three bushings: front, rear and sway bar bracket bushing. Should I consider changing all three?
Sep 5, 2010 at 3:07 PM
  • 110,251 POSTS
I would try spraying one at a time down with something like WD40 to see if the noise stops. That way you don't have to spend as much.
Sep 5, 2010 at 6:02 PM
